I've been wanting to add strobes to most vehicle I've ever owned. This 2012 Can-Am Spyder RSS is not an exception.
Picture 1: bottom cover taken out by unscrewing 7 torx screws at the bottom, run a 4-conductor wire in frame from front to back
Picture 2: fit the position where the strobe would be mounted. I've bought 4 Hornet 8 in Blue and White from Extreme Tactical Dynamics. Mark where the 2 screws that hold the light to the side panel
Picture 3: drill the first holes where the screw mark were made. You don't have to drill the hole, but you'll risk the plastic to crack as you drive the screw in
Picture 4: the second hold was drilled. Repeat the same steps as in pictures 2 - 4
Picture 5: shows the 4-conductor wire thru the frame (back)
