stripped threads
copilot
I think I pulled or cross threaded one of the holes for the tranny filter. Would anyone have an idea to help fix problem? Ideas like let dealer do it is not accepted as an alternative fix.
If it's cross threaded you can sometimes save it by carefully cleaning threads up by re-tapping. If there no threads left as in stripped you have 2 choices .One drill and tap to next size and drill clearance size in cover. The best fix is to get a heli-coil kit .You can usually get a kit with drill and tap and insertion tool.Drill ,hand tap for heli-coil. Use tool to screw heli-coil to right depth break tang off and you have a thread much stronger than oem.
Those are two very good ideas. When you put a Heli-coil in aluminum it actually is stronger than the original hole, however you need to have enough material around the hole to make it work. If you don't enough material, then the idea of going one size larger will be more likely to work.
Thank you. Learn something new almost every day on this forum
Agree...
The heli-coil is the way to go. Been using them for years in all the shops I worked at and now at home for any bungled bolt hole...:thumbup:
Tap
Try to tap it first. Might be enough metal to work. Plan B is the helicoil, or a threadsert. PlanC is weld the hole full of aluminum, drill and tap. Plan D; Thermal incident. Things happen.......
Installing a helicoil is a good repair plan. But it is more work then it may appear. The HCM cover needs to come off so that you can get to the threads in the main HCM casting. See item 53 below.
attachment.php
Another fix I know some have posted they have done. I think it is just crude and don't recommend it, but I am putting it out there. Drill all the way through and use a nut on a longer cap screw.
If you've never done a helicoil find someone that has to help you. I made the mistake a few years ago of recommending this exact same repair to someone thinking they knew their way around a toolbox, and they waffled up the install, dumped oil all over the place as the cover came apart, and played the blame game.
Good Luck!
Sent from my Nexus 6 using Tapatalk
