I have a 2015 ST Limited and I was cruising down a country Highway in 3rd gear and when I attempted to shift to 4th, I could tell the clutch engage but the bike did not shift. Then I attempted to downshift to second. Again, the clutch did its thing but the bike did not shift. So I was stuck in 3rd. When I stripped off the Tupperware I found that my gear shift lever at the end of my shift linkage was loose. I could also see small bits of metal where the lever Meets the gear shift Rod ( the rod that goes into the engine casing). The pinch Bolt was firmly in place but I could grab the lever and move it in and out more than one would expect. When I removed the pinch bolt, halfway across the thread I could see the threads were damaged/sheared where the threads contact the shift Rod going into the engine.
When I took the gear shift lever off, it was obvious that the ridges were worn and as a result as the gear shift linkage was pushing back and forth thyong to shift, the gear shift lever was stripped and as such not turning the gear shift rod.
So I have a new lever on order. I'm just wondering if anyone else has experienced this and what I could have done to avoid being stranded in 3rd gear? Ideas? The tryke is one year old and has 20,000 miles on it. Seem quir stange to me.
