Stored Code P0136
Damaged O2 sensor, damaged circuit wires, damaged connector or damaged ECM output pins.
Check fuse
Disconnect HO2S2
Measure voltage between harness connector HO2S2-1 and ground. (Expected value = 11 to 13 volts)
Measure resistance between HO2S2 pin 1 and 3 (Expected value = 14 to 15 ohms).
Disconnect ECMB
Measure resistance between harness connector HO2S2-3 and ground. (Expected value > Open).
Measure resistance from harness connector: HO2S2-3 to ECMB-L3 (Expected value: < 2 ohms)
Thanks. All Greek to me. I pulled this up tonight. 2010 RT SE5 went into limp mode yesterday in Daytona. I'll call the dealer on Tuesday.
If you pulled it up on the display, it is not a stored code, it is active. Sounds like either the O2 sensor is fouled/bad or there is a wiring issue. Could also indicate a fouled spark plug. This might clear on its own if it was caused by a momentary slug of fuel or soot through the exhaust.
Thanks Scotty. You were the first to respond to "My First Limp Mode" thread yesterday. Thanks for the comments without the sarcasm. Being a new owner, limp mode is of great concern to me. Some owners have had shutdowns occur while traveling in heavy traffic. That can be very dangerous. I was apprehensive about my purchase from the start. Yesterdays event didn't make me feel very confident in this otherwise nice machine.
I'd see your dealer. This can be dealt with, and is not common. Once you work out the glitch, your Spyder should be fine. Sorry for the off-color comments and sarcasm on the other thread. They were embarrassing, and not representative of the way SpyderLovers usually respond.
Spyder was checked by the tech today. Could not find anything wrong except for some updates that needed to be done. This still does not tell me what happened on this past Saturday. To say i'm perplexed is an understatement. I am supposed to go on a ride to Charleston, SC on Friday. Feeling a little uneasy and should not be when i'm riding. This is suppose to be fun.
As I said, It is not uncommon for an O2 sensor to "burp" once in a blue moon. This results in a "Check Engine" light, usually. They often leave no code behind. If it clears, and doesn't happen again soon, I would not worry.
Check fuse
Disconnect HO2S2
Disconnect ECMB
Doc is basically telling you, and all of us, that this is what the maintenance manual list as the "Cause" and then the "Service Action". The fault is listed as "LAMBDA Sensor 2 upstream cat. range/performance" and involved the ECM Module (ref: MidWest Manuals p279).
This may info basically means > "See Your Dealer" :roflblack:
As an additional note, intermittent electrical faults are the hardest to troubleshoot for any tech because it may check "ok" then revert to "fault" when not being checked. Most of us do not have the kind of money to justify the "shotgunning parts" to see if it fixed the problem. It may take patience on the owners part to wait for a hard-fault, unless they want to spend money "chasing the problem". No easy answer if nothing is found.
I understand burps. Things happen. But don't throw me into limp mode for a burp. If that happens on the hiway in heavy traffic it could be disasterous. Just give me a check light and I'll take it in. I would bet a good lawyer could make a convincing case in a situation such as this.
