W
Way2Fast
Guest
Lets take a closer look at the steering problems that affect many Spyders. The Spyder doesn't have a steering wheel like an automobile, it has a handlebar like a motorcycle, snowmobile, PWC or bicycle. The direction that the handlebar is turned determines where the vehicle will go. The Spyder's power steering or DPS can only assist the turning of the handlebar. It can not turn the bar by itself. In all the cases where Spyder owners have reported that the vehicle changes lanes by pulling to the right or left...something other than the DPS has to be responsible for making the vehicle change direction. Once the vehicle starts to pull right or left, any corrections taken by the operator seem to be hindered by a locking or stiffness in the steering, forcing the operator to over steer and over correct, making the vehicle dart in the opposite direction. This is no doubt caused by a DPS malfunction, but the initial lane change is not. What is making the Spyder change direction in the first place? To my knowledge, no Spyders have excessive play in their steering. It has to be something that puts a drag on either of the front wheels...but only on one of the wheels. The most likely cause would be a dragging front brake on one wheel. The severity of the pulling would be dependent on how much brake is being applied to that wheel. The vehicles Stability Control has the means built into it's computer to apply braking force to any wheel when it determines that doing so will prevent a loss of control. A Stability control malfunction might be the cause.
Of course there is also a possibility that the steering problems are caused by it's mechanical design. The linkage could be binding in some way. Regardless, on a Spyder with proper alignment, the direction the handlebar is pointed is the sole indication of what direction the vehicle will go.
