stalling issue getting worse along with idle
heyharris1
I posted a while ago that the spyder just randomly stalled. Today, me and the wife went for a ride (75 miles) and it stalled 6 times and when I got home I just let it idle in the driveway and it was jumping between about 900 -1700 rpms for about 30 second to a minute then just sputtered and died. It fired right back up and idled like it should for about a minute then started doing the eratic idle again then sputtered and died. When I bought it the dealership told me it was serviced but is there something else I should look for. It has just over 17k on the odometer. Maybe fuel filter, air filter, replace plugs. Just strange the way it started all of a sudden. looking for advice, hate to pay the dealer 125 an hour to tell me the spark plugs are shot or something retarded like that.
no, not yet. Just took a shower to cool down my fustrations. I have learned not to work on things when I am irritated or I usually end up breaking things. I am going to pull off some panels when I get home tomorrow to see if i can visually spot anything. Sad thing is on sept 11th I got a long trip planned and nowI'm not sure how trust worthy the spyder is. I may end up taking the camaro (even though I don't want to) just so I know for sure I am gonna mane it there and back.
Jim
Curious as to what fuel you're using, is this the first time you've emptied the tank as low as it currently is, I remember my used Spyder having a similar issue last fall, and was suggested to me to run the tank as dry as I dared and then top off with a full tank of no ethanol gas (we're in MN where there's more 10 - 15% mixed ethanol pumps than not). When I was prepping for my Iron Butt ride I carried a spare gallon of real gasoline and ran my spyder dry, put the spare in and filled up with real gasoline and haven't had the issue since. Mine idle's at 1400 iirc.
STALLING AND IRRATIC IDLE
:agree: with the other poster on this ....AND if you see the cracks in the vacuum lines you have Superman vision .... you usually can't see them until you remove and bend into a " U " shape ...... PS replace with SILICONE hoses , they will last the life of the Spyder ......Mike :thumbup:
Vaccum hoses...
:agree: they can fool you...replace them with silicone hose :lecturef_smilie: here are the examples Mike mentioned...
20150726_160909.jpg at rest..20150726_160929.jpg the "U" Stress test...
We'll, here I sit at work pondering the issue so I started looking up parts and I noticed BRP has a new part number for the purge valve as spyderann suggested may be the problem. The old part number was 709000108 while the new part number is 709000443. Wonder if there is a way to find out if BRP was having problems with the purge valve and made changes to it, otherwise, why would they have a new part number. Not even sure that's the problem, gonna go home today and test the purge valve and check each and every vacuum line. One other note my wife said she was able to smell gas fumes but I didn't which also seems to be a problem with the purge valve letting fuel into the canister I guess. I so wanna take this on my vacation but not till I figure this out for sure.
Jim
take photos
hey harris ! hope your mystery is an easy fix , please take some photos , as best as possible , I have a 2012 , so one day this might be my mystery as well ! {what was the price on the - purge value ? }
if they do end up being the issue the purge valve is 48.99 and the canister which I will replace as well cost 69.99. Total will be about 120. Not to bad if they end up being the problem. Oh I forgot to answer Dgoebel, I am not sure what fuel I am running. I just pull up and fill it with premium, I think its 91 or 92 octane. I just figure in a high performance machine why run the 87.
Jim
Please let us know how all of this works out; good luck! :thumbup:
(I'm betting on the Vacuum lines and/or Purge valve also...)
I'm surprised that nobody has mentioned the canister yet.
It might be full of liquid fuel and causing the problem you describe.
Doing a search on here for "canister" should find posts describing the problem .......and a couple of "fixes" without buying a new one.
Filling the tank too full is one thing that can cause this to happen.
In regards to the part number changing, don't put too much thought into that. Maybe there was an improved version, or it could just be they are buying it from a different supplier.
H2O
well, I got it tore apart, the purge valve and canister appear to not be the problems, started looking for vacuum lines, found a few that looked questionable so i replaced them with silicone, still no luck still a constant stall. Tomorrow I am going to replace the spark plugs so my question is does anybody know what the ohms resistence is for the wires so I can test them. With 17k miles should I just replace them. Other than the two questionable hoses I have found nothing so far that would justify it stalling.
Jim
This is from the 2010 RT service manual, I don't have one for the 12. I hope it helps.
SPARK PLUG CABLES
Spark Plug Cable Resistance Test
Inspect each spark plug cable condition. If cable
ends, sheath (insulator) or contacts are in poor
condition, replace them.
If cables are in good condition, carry out a resistance
check as per following.
Disconnect each spark plug wire from the coil assembly
and from its spark plug.
Measure each cable resistance and compare to
following chart.
CABLE POSITION CABLE RESISTANCE
Front cylinder 5.11 to 8.72 kn
Rear cylinder 3.24 to 5.53 kn
If cables do not meet specifications, replace cables.
SPARK PLUGS
If there is a fuel filter, you should change it.
And I haven't seen much about a plugged tank vent causing a vacuum in the tank with Spyders.......but that is fairly common with some bikes.
And even if the canister looks OK, I would do the part of the removal procedure that disconnects and blocks off the hose to effectively remove it ......before taking it to a shop.
And a healthy dose of a multi-purpose fuel treatment might help rule out bad fuel.
SPARK PLUG CABLES
following chart.
SPARK PLUGS
Since you're already hip-deep into it: get yourself some new plugwires from BajaRon. His are the best!
I talked to my mechanic yesterday about your problem. He said he just had one in with the same. He said go to the canister and pinch the hose while it is running. In his case, that isolated the canister and it ran better. Said the canister was full. In the early days BRP had the wrong program for the purge valve, making it stay open too long making the bike run lean. Sounds more like fuel than spark to me.
Jim
Jim, let me tell you my tail, earlier this summer I had the same symptoms, I had already changed plugs and wires several hundred miles before, I changed the vacuum hoses, did see some crack after I bent them, still stalled, plugged purge valve, still stalled, check checked thottle boots and changed fuel filter, still stalled, even though I had rode over 1/2 tank of fuel out I poured in some sea foam to rule out water in my tank, still was stalling at idle, kept restarting it and held the thottle open to keep it running, after about 5 min it started idleing again, figured nothing to lose so took it out for a short ride, got home and it was idleing fine and still is.
The only thing that I can think of is I had a dirty injector and the sea foam cleaned it up, I am not saying that it will fix yours but what do you have to lose? There are better injector cleaner out there than sea foam but that what I had on hand.
Good luck
