Ok.. I decided this needs to be posted here rather than the general board.... As most may know, there is a heat issue with the 13 ST's. FB's had enough heat to melt the plastic cover on the brake master cyl. and she was having issues with boiling gasoline in the tank. The temps on the engine are running in the normal area, but the heat load on the interior of the Tupperware is excessive. Pulled the rear spark plug this evening, and it showed a very lean condition, which could lead to above normal heat in the exhaust.... which could lead to other issues we are seeing. Here is a pic of the rear plug showing a very lean condition.
