ST handle bars can they be transplanted on RS
FreedomRings
I would love to take the handle bars from an ST and the stereo from the ST and put it on my RS can it be done?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Don't know..!!
if they can be but you might check the cost effectiveness as opposed to aftermarket mods available...oops..!! If it is the look that would be the only way so maybe some one knows if you can swap them out...:thumbup:
Anything can be done, BUT IT WOULD ALOT OF DOLLARS, so I would say no. Due to the throttle bodies different and computer would need a new apps. to make it work and that's only for starters and you would void your warranty. That's IMHO.
Mike
I'm not sure about the stereo, but the handlebars can be swapped from an ST to a 2013 RS. Huckfin did the swap already and it sounds pretty simple. Keep in mind the ST and the 2013 RS have a 4 bolt handlebar setup. The pre 2013 has a 3 bolt setup.
