Squeaky Wheel
LEEB
I have a new 2014 RT-S with 800 miles on it. Today when I took a short ride and pulled the Spyder into my garage I hear a sharp intermittent squeaking noise coming from the left front wheel. I was not on the brake at the time, so it shouldn't have been the brakes. Any ideas on what this noise may be? Could it be a wheel bearing or just the brake pad scrapping the rotor. Thanks for any help you can lend!
Relax..!!
things are still settling in and pads have a tendency to hang up a bit or an bit of brake dust will make them squeal..if you ryde her a bit and apply the brake afew times should clear up. Usually backing up and applying the brakes helps too. If it continues and becomes constant have it checked out...:thumbup:
Thanks! I'm taking it out first thing in the morning for another short ride to see if the sound goes away or changes. If it's gone, then wifey and I will take a nice long ride. Other then this noise, we are loving every mile on our new Spyder. I'm feeling more comfortable every mile.
