Roadster Renovations
Roadster Renovations arrived in Houma, La after a 19 hour, 850 mile overnight run. We grabbed a bite at the local Sonic and had to feed a few of the seagulls that were hanging around, then went on a 40 mile ryde out towards the bay. It was beautiful (and hot, almost in the 90's), but as always when moving on the bykes, it is easy to cool down. One curious thing I noticed on this initial ryde that these folks bury their dead above ground in crypts. I kinda knew that, but I had forgotten. Lots of fishing boats out towards the gulf area, which is understandable. Many of the homes are built on stilts or blocks for high water situations. Kinda reminded me of the outer banks in North Carolina. A very neat area! If you are not coming this year, you should make plans to make it down here.
We will be starting installs on Thursday and I have most of the day booked already, however, as you know things can happen so stop by if you need something done (or just to say HI).
We will be selling and installing the following:
Spring Stiffeners - this stiffens the front suspension on the RT, helping them to corner better.
Air Ryde Rock Armour - This "cup" protects your airbag from sharp rocks that collect on the swingarm.
Side Case Upgrade/Repair Kit - This kit helps to strengthen the side case plastic that is a known problem of breaking. It works best on unbroken hinges, but it can repair a broken on. One of ours broke in 2015 and we created this kit and are still using it to this day.
Top Case Mirrors - Add a mirror in the spot where it should of had one. Great for helmet hair.
Blind Spot Mirrors - These mirrors pivot and greatly increase visibility.
RTBK kits - these kits allow the BRP F3 idler kit to be installed on the RT's.
Ultimate Vibration Damper Kits - These are our upgraded kit that comes with a 2 warranty on the pulley and bearings. (stop by for a demonstration of the differences)
Send me a PM if you would like to schedule something done.
If there is enough interest, we will do a daily workshop of how to correctly replace and tension the pulley bearings on our kits.
We are still mailing orders out daily, so feel free to order at our online store and we will get the items to you.
http://dochumphreys.wixsite.com/roadster/products
