Riker
Just went out and surveyed the strike. As your looking from the front, it hit about 6 inches left of center. Based on the way the muck and splatter was, it appears the skid plate did an amazing job. It cut/pushed it out to the left under the a-arm. After exiting from under the a-arm, there was muck on the rt side radiator cover and spatter on the highway peg. There was no impact with the front of the Spyder, the skid plate took it all. I was cruising down the highway at about 70-75 mph. Just as I go to pass a cager, there is a huge piece of road kill in my path ( assuming deer ). At this point I could not avoid it, so I tried to get it to the inside of the wheel. Thinking about it now, was probably better I hit the skid plate, as large as this piece it was. I stood up on the pegs some for the impact, thinking there was going to be a bounce, but apparently it sliced right through it ( I was lucky I think ). As I looked back in the mirror, the large chunk, plus the one I sheared off were tumbling behind me. Took the hose to it and all is ok..... Thank you guardian angel:thumbup:, and Spyderpops :thumbup::thumbup:
