Spyder_Cowgirl
GOS member (Girls On Spyders)
Kudos to Harvey Clark (aka Spyderpops) -- wanting to install both the High Mount Run / Brake light and Harvey's 4-piece LED Run / Brake / Turn ... but not sure the two are compatible. So, sent an inquiry that Harvey responded to; yes, compatible as long as the four LEDs are plugged into the bike side of the harness first. A follow-up phone call indicated that I would need the HMT-CVT part to have the high mount operate as both run and brake. So, placed the order while on the phone. A few hours later, get an e-mail from Harvey that the extra CVT part is not needed as his harness can be adapted to take it's place --- AND, he had proved it worked by testing on an RT in his shop. :yes:
So, not only did Harvey save me some bucks, he is sending both units knowing that it will all work. That's customer service at its finest!
Thank you Spyderpops for taking the time to test out your theory that your harness would handle it all .... All the best ... Ann
