Dan_Ashley
I got tired of wearing my insulated 1/2 chaps so I bought a Spyderpops Block Off plate. It arrived and I noticed it was black. They are all black, I guess. Since I have a Viper Red 2012 RT, of course I wanted it to be Viper Red!
I purchased a can of BRP Viper Red spray paint from a non-OEM on-line vendor. When it arrived, was I happy or what!!!
I sanded the gloss off the block off plate with 400 grit, and primed it with plastic primer. After waiting overnight, I sanded it again with 600 grit, and applied a first coat of Viper Red. Waited again overnight, sanded it with 1000 and a second coat of Viper Red. Did this again, making 3 coats of Viper Red.
Did I mention that MY Spyder is Viper Red?
Once again I waited overnight, followed by a 1000 grit sanding, but this time I used a 2k spray top coat. Waited four hours, sanded and a second top coat.
Now my block off plate is the right color: Viper Red!
So I installed on my Viper Red Spyder, following the instructions exactly.. .this took all of maybe 15 minutes--including reading the instructions repeatedly. They are easy to follow, but I am not mechanically minded, so I have to be extra careful.
Finally it is installed and it looks beautiful--not like an add-on at all! Gotta go for a test ride. Now this was not a Ryde, it was a test ride. I headed out onto a back road, around to the freeway, through town, back to another back road and through town again. All total about 75 miles.
Results: My right foot did not get hot when I used the highway pegs. I noticed a very little warmth in town when my foot was on the brake at a red light. But it was very comfortable. The Spyder is the real winner here though. It normally reaches the 1/2 way mark on the analog heat gauge within a mile or so of starting out and then stays at this level. Today it reached the 1/2 Mark at about 10 miles, and I was at a red light. It cooled down to the 1/4 Mark on the freeway, and then up again to the 1/2 Mark going through town. The spyder seems to be running significantly cooler, but I did not measure before and after with a thermometer...so, I can only say "seems to be."
By the way, the thermometer on the dashboard was reporting 77 degrees today. I know that is not the ambient air temp, but that is what the Spyder thinks it was.
So, the block off plate installation and test was a huge success!
