SpyderPop Belt Guard Pic?
ulflyer
Well-known member
Does anyone have a picture or two of the guard installed?
Can't quite make out what it looks.
I can't get my camera (or myself) into position to take a pic.
However on my GS the piece is L shaped & the small part of the L is stuck to the underside of the swingarn by the tire & the longer side of the L hangs down close to the tire
The adhesive is very strong & you have to get it lined up pretty good as you pull the protective tape out.
Best I can do..!!
Can't see much once installed but the instructions are pretty clear...
20130302_095737.jpg 20130302_095945.jpg the small wheel is part of the belt tensioner.. Good luck
Thanks Oldgoat, and Chupaca, your pic was clear enuf that I could see, and understand, how the guard worked. Just now sent my order in for one.
