Spyder RT-Ltd Tupperware - upper panel fixed peg broken?
What year? The pre 20’s are pre bent to slide into grommets. Don’t slam them in or pop hard with hand. Simply little white spray, line up and gently push in starting front to back. The angles are set. Don’t loosen the heads at all or they will rotate creating problems.
DO NOT under any circumstances loosen the pegs! Don't get a security torx driver. Also wrapping the grommets with a small zip tie helps hold them in place. Put a little windex on the rubber before you try to push them in. It makes them slick but dries quickly and won't harm the rubber. You may have to move one or the the other of the panels around a little to get them to line up better. Just be patient and work work with it and thy will go in.
BTW welcome to the insanity. Have fun and have miles of smiles.:welcome::welcome:
The ABS can be glued to a fairly strong joint with ABS plumbing cement and GP plumbing cleaner. I buy my cement on Amazon and get pretty fresh stuff. If you need to make up parts, wreck take-offs from your local motorcycle service shop can be carved into what you need.
