johnc1921
I have a 2013 Spyder RT Limited. I had to replace the belt shortly after I purchased the Spyder in May, 2019 due to a hole punched thru the belt by a pebble. Since then I have noticed the new belt will wander from good alignment near the inside rim to the other side of the drive sprocket. The attached picture shows the belt's current alignment. I have the rear wheel off the ground and my Kricket II registers about 230#.
Maybe reduce tension? Maybe add a belt tensioner? Is this normal?
Thanks.
Thanks.
