SPYDER RECALL
ekfraz
Just recieved an e-mail service bulliten from BRP stating that the Blinker Fluid on 2013's an 2014 Rt and RT-S before they are ridden again, If you ride it then you run the affliction of catching the real Spyder bite.
What the H@## are you talking about?
:yikes:
If your dealer doesn't stock it; here's a good online source... :thumbup:
http://kalecoauto.com/
I can't believe the string of recalls . . . right after this one, I received a warning that BRP is insisting that Spyder owners have a mixture of compressed N[SUB]2, [/SUB]O[SUB]2[/SUB] , Ar, CO[SUB]2[/SUB] ,Ne and CH[SUB]4[/SUB] injected into their tires! :yikes:
I saw that one, and it flipped me out! :gaah:
I'm not going to submit to this indignity! :banghead:
I'll just keep using air from my tire pump, and they can kiss my
Added
I refilled the blnker fluid yesterday when I installed the New Tricled blinker lights. Checked the head light fluid as well. :clap:
This is a real must know THX. :yes::yes: RIDE ON :2thumbs:
Elios are now scheduled for 2015 delivery. They claim to have deposits for 13,000 plus. They have also updated the looks a bit.
And that's no April Fool.
On my 2012 RT, I replaced the blinker fluid with granominclinators. It works better, and does not catch fire as easily.
There is also a bulletin 1234-99GB6 Requiring the changing the air in all tires once a month with fresh air to improve fuel economy in all Spyder Roadsters!!!!:roflblack:
If they can pull this off at less than $10,000, I think they need to re-brand the company to Houdini.
I kind of like this kit - of course it would be 25% cheaper for the Spyder!!!
400x300xLowerKit.jpg.pagespeed.ic.BFT9jDss83.jpg[h=1]Lowering Kit[/h][h=2]$19.95[/h]Some people spend hundreds - even thousands merely to lower their car! Some people even cut their springs - that is the wrong way to lower a car! Why bother with different bolt sizes and components, when KaleCoAuto's do-it-yourself lowering kit is a mere four piece kit! Installs in minutes, just insert one per tire and you'll be the envy of every lowrider in town! Now available in standard, chrome, and gold.
