I'm looking at getting the JMCB-2003 audio System is designed for the sypder. It has a CB radio on it and I was wondering if anyone else is using it or what is being used for bike to bike communication and rider to rider communication?
The audio system is top notch but the CB has a lot to be desired, it's not very useful at 60 mph and the range is very short. Too expensive for the CB being poor. I have it matched correctly and it just doesn't perform well. I think it's the noisy platform (wind and motor noise).
For the bike to bike/ driver to passenger stuff get a Bluetooth system with J&M headsets.
The CB Band width is very sensitive to antenna size, design, location and ground plane (what it is mounted to). It also has to be tuned for Standing Wave Ratio, which is just a fancy term for signal efficiency.
Like running a 100 hp into a bicycle drive tire. You aren't going to get anywhere.
Some people rave about the J&B CB, others hate it. It's usually not the radio, it's usuall the install.
The frequency range used in Blue Tooth systems is much less temperental and will give a more uniform performance (same systems being compared)
Everything you say is true. I've been an RF engineer for 30+ years. That said, after I matched my systems and getting poor results I had a 3rd party check it and they said it was matched about as good as you can get without changing anything. So I went with a Firestick NGP antenna because of the poor ground plane any motorcycle will have. It has been preloaded at the base to help overcome the lack of ground plane. There was an overall improvement but still not the desired results.
I could go with a longer base loaded antenna but at that point it will just start getting in the way and increase the risk of getting accidently broken.
Again J&M products are great but with the CB and the Spyder combo doesn't really cut it. I can see it working well on a Gold Wing but not a GS.
Got the JM set up and intercom and Ipod hook up are great! The CB sucks big time as do the cords ! I have replace 1 helmet cord and 2 lower cords in 14 months at 30 bucks a pop . Sure it's under warranty but ship it back on your own dime and wait for them to determine it is bad and ship you another one takes way to long . My Scala Rider does the same thing at a fraction of the cost but you have to remember to recharge it !
I run with the Red Knights and they use CBs ,my range at best was maybe 200 feet the others on Wings and Harleys was at least a quarter mile !
Oh yea, I forgot that part about the lower cords wearing out too fast... :sour:
They have a 2 year warranty, so why are you paying for them? I have sent mine back and they sent a replacement the same day they rec'd it.
Great customer service!!!
