BajaRon
Well-known member
I am told that there is a video out there claiming that the BajaRon End Links for the Spyder can be modified to work on the Ryker. This is unfortunate because several customers have purchased my Spyder end links based on this information.
There are several reasons this approach will not work. These two link versions are different lengths. Link length is critical. Too short or too long and you reduce the effectiveness of the sway bar. This is one reason I do not make adjustable link sets. Adjustable end links would be counter-productive in this application.
Since I make end links specifically for the Ryker at the same price as the Spyder end links. There is no reason to attempt to modify end links which were not meant to mount to your Ryker.
If you have any questions, I am always available to help. I am all about an informed customer.
