Spy 5000m alarm
Cut and paste " Spy 5000m alarm " into Google search. There is a ton of info.
I'm using it on my RS. Pretty straight forward wiring right from the supplied diagram.
I did not hook up the remote start. Seems to work good. Hardest part is finding a location for the proximity sensor. Mine was not sensitive enough under the seat so I put it right under the plastic just In front of the seat.
It will allow people to look and get close but as soon as you get within the "Y" profile and stay there it starts to get angry.
I doubt you can get the remote start to work due to the security key the spyder uses.
Bob
That should be easy enough. Take the antenna off the ignition switch and mount it, along with a programed key somewhere under the bodywork. Done. The DESS computer should not know the difference.
Could take more than that since you have to push the mode button prior to startup.
Other than that it would be pretty straight forward. Just never had the need for remote start on the Spyder..
