Spring loaded trunk release for RS
bumper60651
I understand there is a way to make the RS model trunk release, spring loaded. So that I don't have to run back to the hardware store 10 times, is there any information out there on how much tension the spring should have and what size washers are used? I look forward to your replies. Thanks
Others more knowledgeable than me will chime in. I was given the spring by a forum member. But I didn't do anything fancy with it. I used some silicone and just sort of glued it in place around the latch pin. Doesn't exactly look very good. But it works!
I went the way of using the spring and the copper plumbing end cap. I really like it and it's easy.
If you go to the ShopTalk section there is a thread by bjt in august 2008 titled "hood spring" (I think) that has pictures and description of what he did. Good luck. (I did a search under "trunk spring" to find the thread).
If I remember right (and it's going on 4 years) the #165 spring from True Value Hardware works. But if you know what a spring-nut is, the spring off one will work, too.
john
I just grabbed a spring from my box of assorted springs, put it on the striker spade, and tighten it between the two nuts that hold the spade . I also attached a cable to the locking arm and ran it out the side behind the front tire, So i could open the trunk without using the key.
There are a bunch or variations on this, using various springs. A search for "trunk spring" should net you several posts. The newer Spyder RSes are equipped with a spring at the factory. The easiest way may be to have your dealer order you one.
