SPEED SENSOR TOOL
xpeschon
MOgang Member
ok,, I dug into the tool kit that I got with the spyder to check the tire pressure and to do a once over on the exposed screws just to make sure none of them have come loose,,, I'm running 20 psi in the front tires and 28psi, after reading several threats this is what I came up with,, Now as I was doing all this I noticed a little chain hanging out of the tool bag and on the end of it there are 2 gauges ( simular to a filler gauge for gapping spark plugs) that say "Speed Sensor" on both of the gauges,, OK I am lost here, what in the heck are these for?
Thanks in advance
Joe
Thanks in advance
Joe
They're for setting the gapo on the speed sensors when you remove the rear wheel for work or a new tire.
OK
Thank you,, I should have just PM'ed someone on this.. I will try to get rid of this threat now,, Thanks a bunch brother
I had seen them but figured they were for checking valve clearances. You helped us learn something again!!!:cheers:
No need to get rid of this. Like they say, the only dumb question is the one you don't ask. Besides, I think that you cannot delete your thread once someone responds to it. At least I haven't been able to delete any of mine that had responses.
You got it
Yah I re-thought that one about deleting this threat, I am going to keep it there.. As for Dudley,,, Dude I thought the same thing but then I took a hard look at the thickness and thought " Nah I don't think so" but Maybe, just Maybe.. I'm glad I was at least able to have someone answer the question right away, thats to cool.. Later guys and lets see how this threat goes then..
Joe
