Sometimes when I try
oe3spyderguy
Sometimes when I try to adjust the air ride on my 2012 RT-S SE5 instead of the 5 dot adjustment pop up it says manual :dontknow: before I take it to the dealer does anyone have anything?
There are a couple of possibilities. The ACS sensor could be disconnected or the cluster could be programmed with the wrong ACS sensor limits. There are some other, more remot possibilities. A visit to the dealer is probably in order unless you find the sensor link bolt missing. If the height still adjusts manually when you hit the switch again, it is probably the cluster.
It also could be something simple like a pinched wire running to the ACS lever next to the belt. Don't ask me how I know these things!
KYSPYDER
