Somebody please tell me....
Buggy
The BRP has finally moved the rear tire valve to the right side of the back wheel....what a pita...it has only been years on the wrong side. End of rant!
cheers
on the left side you have to deal with the belt
on the right side you have to deal with the HOT muffler
leave it on the left side
Cruzr Joe
;) If we've got to have something to gripe about: I'd rather it be this; than something like a poorly-built engine that leaked oil and coolant like an incontinent dog leaks... everything else! :yikes:
This is an easy mod.
You can easily do this yourself, remove rear wheel " I would do it when you replace the rear tire"
Go to a truck tire service company and buy a curved metal chrome valve stem, drill the correct size
hole needed for the valve stem then install the tire and install the assembly on the Spyder you will have
2 valve stems in the wheel NOTE: BE SURE YOU DRILL THE HOLE EXACTLY 180 DEGREES FROM THE OTHER VALVE SO YOU DO NOT CREATE AN OUT OF BALANCE CONDITION.
Or you could go to your local Harley Davidson dealer ans spend 10.95 for an extension hose to check and air up your tire. Thats what I did. Very easy to install and use. It has zero air loss.
Cruzr Joe
:firstplace:
& you can reach thru a belt not the brake rotor :p:lecturef_smilie: Especially without bumping a HOT exhaust:yikes::gaah:
:lecturef_smilie:Dont you mean "Incontinent HOG":roflblack::roflblack::roflblack::roflblack::roflblack:
