redrazor
After my first 200 miles on my 2014 RT Limited:
1.)New front (car) tires (set @ 18-20 psi)did make a significant improvement in. stability. (2.) K&N air filter helps acceleration a little bit. (3.) Tupperware panels make things quite a bit harder to make adjustments and do other maintenance. (4) Rear shock air pressure set at 40 psi made a better ride than the 20 psi that was in it when I got the RT. (5.) Parking brake does not hold well when parked up hill (small rubber chock block in trunk helps). (6.) Radio is not too user friendly.
(7.) It takes 9 or 10 half-hour rides to really get the feel of the 3 wheel idiosyncrasies of these machines...especially after 40+ years on 2 wheelers. (8.) My RT rides much smoother, and handles much better with a passenger (my 118 lb wife) on board!?!? :clap::chat:
