So I bought these great dual color fender lights at spyderfest. So the question is?
kbfk
How do you get the corresponding fender to flash when the turn signal is turned on. ( ie if you turn on the left turn signal the left fender blinks). I believe there is a control module out there which will control this function. I have an RT if it matters.
Thank you for the help.
when you buy the Fender Tip kit from Custom Dynamics, like I have, it will include an LED light for the front fender, as well as wiring to tie into the turn signal wiring in the back if the instrument panel allowing the fender lights to work as turn signals. I'm not sure if TricLED sells this setup as well.
:agree: You need the fender tip kit from Custom Dynamics that runs from your mirror turn signal down to the fender tip light,then anything you tap into from the fender tip light will blink as a turn signal.
