sluggish 1st to second shifts
Questions
I have a 2011 RT and it is very sluggish, sometimes refusing to upshift at all, when I am first running it. I always let it warm up for about 3-4 mins before pulling away. Is this a common issue? Seems to go away after 15 mins of riding. I am not pushing it either.
I've found that shifting around 5,000 RPMs always gives me smooth shifts even with the engine not fully warmed up.
Sent from my SCH-I500 using Tapatalk 2
"Essie" or "Essem"" I'm guessing that it's the floppy-paddle one...
A sluggish upshift also seems to point to low oil levels... I'd check that, just to be safe!
These bikes are pretty sensitive to oil levels... :shocked:
Check the oil level, Could be a hair low. Also you might be trying to up shift at a too low rpm, Most likely that's the problem. :popcorn:
Check oil level. The other possibility may be that you do not have the revs's high enough for the upshift. 4500+ is recommended. Give those a try and let us know if it gets better.
