Slow leak in rear tire
Bummer..!!
you could go most anywhere to have them try and find the leak. Problem is most shops will not plug a tire unless the hole is in the center of the tire and they pull the tire out and patch from the inside. I plug my own with a mushroom plug kit. Can find them on amazon ebay etc. These eork well and have never had a problem after using them....:gaah:
haven't found the leak, noticed it lost 10 lbs in 7 days. Aired up to 28PSI, will check again in a few days.
If its not something obvious like a nail in the tread, take a spray bottle and fill it with water and dish soap. Spray it around the bead, stem, etc etc. Your leak will bubble
Make sure your valve stem is tight and if it is, chances are you
have a tack or nail somewhere in the tire. Might try jacking it up, turning wheel to look for such. Also you can increase air pressure to 40lb or so and listen closely while you turn the wheel to see if you can hear any air escaping...although not likely. Another method, if its possible, use a bottle sprayer and squirt soapy water all over as you turn, watching for air bubbles. Otherwise, have dealer pull and examine from the inside.
I hate to say this; go get a new tire... :shocked:
As much at it'll stink; it'll stink a lot less, than if that tire lets go on you at speed... in traffic! :yikes:
What's your life worth to your family?
Most MC shops will not patch a MC tire and they will probably treat the Spyder the same way. There are some dealers in San Angelo that sell Ride-on, probably the MC rather than Auto variety, but it will seal a slow leak in the tread area with no problem. Probably spend around $30, but you get a sealed tire, better balance, and more miles on that tire. The ride-on site has a dosage calculator, for the stock it is 16 oz IIRC. If you decide to order it online instead, you can use the code lamonster to get a discount.
