Slingmods adjustable luggage rack
The Slingmods site specifically says the MaxMount is required for installation. Furthermore, it is shown with the pillion seat attached to the MaxMount using the same attachment points as the top case.
Thanks. Looks like I'm buying it. I ran outside and double-checked as well and the mounting holes on the bottom are available.
I have it also. Also have top case on my max mount. Only thing I'd mention is that it really isn't "adjustable" in that if you use the second set of holes (that make the rack closer to whatever you have on the max mount, it will cover up the hole to mount the accessories (2-up seat or top case) and render them uninstallable. The only position that works is the one that places the rack in a more rearward position. Also be careful not to overload the bike when 2-up, as the metal flange can come down on top of the rear fender & tire if the spring is compressed to it's downward limit. See my prior thread about bashing my fender this way last month.
I got the adjustable luggage rack installed and I'm wondering what can I fit onto it. I can probably get another top case and drill through it and bolt it on, but I'm wondering what you guys got?
Another thing I was looking at are those collapsible storage totes that you can stack as well.
sKIZo, do you need to have the fender extender that the Rally has installed to use the Nelson Rigg bags? Measuring my 900 ACE it looks like the bag will be too long or is this just me overthinking it?
I’m looking at the Nelson-Rigg Sahara dry duffle bag in black #se-3000-blk $119 Dimensions 20”L x 10”W x 12”H, but have not pulled the trigger yet.
