side mount license?
has anyone found a side mount license plate frame , I am wanting to remove the rear tire guard and put on a side mount plate like a chopper, no luck finding anything
yes i did
Its pricey but well manufactured and it's from a sponser of this sight Raw design what makes it different is you can go from horizontal to vertical in 3 seconds. They have a lighted frame for it for also. All you have to do when you get it is remove the left rear axel cover tap the bracket in their the tighten the bolt and you are done accept for the frame. There are less expensive ones out there i believe Kewelmetal has one? I also removed the backfender if i have to put one on i'am going with one off of a kawasaki i have seen acouple of people on this site do it and it looks way better than stock. Take pictures when you are done. This here is what i did when you disconnect the original brake light just route it to the other side and use wireloom to conceal and protect it i used black zip ties to hold it in place just because i did not want to drill into the swingarm to hold it down with a clamp. You will have a bunch of extra wire i do not recommend cutting this off in case you ever want to put it back to stock.
