Show Chrome 41-162 trailer harness + 5 to 4 way converter
m_lavergne
Hi,
Has anyone successfully installed a Show Chrome 41-162 trailer harness with a 5 to 4 way converter? If so, which 5-4 converter did you use?
Here are my results:
- Running lights: OK
- Brake lights: OK
- Right flasher: Ok, but left flasher flashes dimly (There is 5-7 volts going to the left flasher)
- Left flasher: Ok, but right flasher flashes dimly (There is 5-7 volts going to the right flasher)
I have tried 3 different 5 to 4 way converters.
When I check the voltage on the output side of the 41-162, everything appears to be ok. No voltage on opposite flasher.
Any ideas?
Thanks,
