That may be so, Pete; but with metal links the bushes seizing won't be
anywhere near the same problem as it is when the bushings seize on the OE placcy links! :lecturef_smilie:
Those metal links from BajaRon can withstand a whole lot more stress & pressure before
they will begin to flex, and even if the bushes on the metal links don't move, all the twisting forces will still be transferred into the anti-sway bar, which is
DESIGNED to flex under stress, and your ryde is still good/controlled by the bar doing its job!
hyea:  With the placcy links, when the bushes don't move, the next '
weakest link' (pun intended!
 ) is actually those placcy links, so once the bushings seize,
they start flexing - and once the placcy links start flexing under stress, it's juuust a matter of time before they fail & snap completely! :shocked: And all the while the placcy links are flexing & degrading, the anti-sway bar
simply CANNOT do its job properly because the torsional forces are at least partially being absorbed by the flexing links,
so your ryde suffers!! And when they eventually fail, as they
will unless the problem is resolved/they are replaced, your ryde
REALLYsuffers!! :yikes:
I know which of those two options I prefer
 and if you have any doubts about which that might be, it's the one with the metal links that means the anti-sway bar
STILL works even if the bushes don't move at all!!  :thumbup:
All that aside, didn't BajaRon recently mention that he'd done or was doing something about improving the 'moving life' of those bushes in his latest iteration of those metal links?? Ron??  :dontknow:
