A friend I haven't met yet reached out and asked me if I could make a shifter tip replacement (SM6) that's longer than stock so I said I'd take a look. I figured it'd be easy, a couple of round bits welded together with some flat bit in the middle. Turns out the stock shifter tip is splined, which added a whole degree of difficulty. Anyhow, there were 8 splines so I figured I'd give it a shot.
Untitled by Uncle Grr!, on Flickr
I made an attachment for my lathe a while ago that allows me to index the chuck to 60 plus 4 points, which gives me a lot of divisors. The plus 4 is what allows me to index by 8. I also made an attachment that lets me mount my cordless drill to the toolpost. This is what I did here.
This is the end result, a series of 8 holes drilled into the end of a random chunk of steel I had laying around. Note that this took multiple tries of different size drills, different diameter hole patterns, and feeds/speeds.
After turning to diameter, this is what I'm left with. Splines! If I had any of a number of other tools I could have made them differently, but that's what I had that didn't involve lots of filing or dremel tool work.
The stock part has a recess in the middle of the splines to allow the locking bolt to positively retain it. Again, other tools would have made this easier but I mounted a 1/4" end mill in my drill rig then turned the lathe on and ground the groove out.
Proof of concept part, before cleanup and deburring.
Installed in the shifter.
Then I milled a slot about a hundred thousandths deep across the center of the top.
And cut a chunk of scrap 1/8" steel down to the same size as the slot
So it fits into the slot tightly
I took an old pin that broke off one of my trailers and turned this piece out of it to size
Then drilled a matching hole in the flat bar and pressed the turned part in
The fit was tight enough that I could do a fusion weld from the back. Got a bit hot and melted the edge there, but I'm not awesome at tig welding yet.
New part next to the stock part. I'm waiting to hear how much longer than stock he wants it before I adjust it to final length and weld it solid.
Edit: I currently have from -.5 to +1.7” adjustment range. Honestly it wouldn’t be all that difficult to make it adjustable too, although I’d have to change the design and redo it all.
