Shift solenoid ground wire
Dtryke
On my first long ride (3 hours) I had trouble once getting from neutral and into first. Had to hit the shift button 4 times. Does that sound like the solenoid ground wire issue?
Check your ride's left side...
Hard to say without knowing the year, and whether the SE5 already came from dealer / factory with the coils' grounding trick installed or not.
Remove the left side red Tupperware and check for these kind of arrangements which show the trick installed.
Saludos, Pilo
