I bought the shad bag kit when I got my bike last year, but they didn't arrive till recently. I installed the bags and immediately hated them. The brackets are huge, they stick way out, and it looked like I had been rear-ended by a jungle gym. Fortunately they were made of regular old metal so I cut them apart and rewelded them back the way I wanted. I had to give up the grab handles but my wife has her own bike and I almost never carry passengers so NBD, plus when the bags aren't on the racks themselves act as grab handles.
Not many pics of the in progress because this was about revision 6, but the short version is that I cut the mounting tabs off the actual brackets then started holding the brackets up various places till I found a good spot, then I'd tack weld it back together in place and check for clearance issues. Finally ended up putting the tubular bag mount above the frame bracket, which I flipped upside down and milled a slot in for the bag lock to fit in. Moves the bags back about 6" and up about 4" relative to stock, and in about 3". I should have taken more pics of the brackets before I cut them up, but if you look around on here you can find pics. I also cut away parts of the bracket that were unnecessary, and ground down and smoothed the welds on the very bottom of the bracket. If I'm honest I'm pretty disappointed in the way the brackets came stock. The shad bags come off by pivoting up and forward which means they can't be placed under the stock grab handles, so they had to move the bags way out to clear. If they used something else like a Hepco Becker bag that side mounts they could have been much less obtrusive. Oh well, it is what it is and I'm much happier now. I'm still in the middle of painting them so all pics show raw steel.
Untitled by Uncle Grr!, on Flickr
Stock
Fixed
Comparison
After
Bracket closeup
Bracket, further
Bags on
Stock
Fixed
Comparison
After
Bracket closeup
Bracket, further
Bags on
