Sena20S headsets
Commander
I'm sure a lot of you already know the answer, but I asked the following to SENA and I am sharing their reply.
I'I plan on getting the 20S headsets (Dual Pack) my question is I understand that the 20S is MP4, I have a 2013 Can AM RT Limited Spyder that came with a Garmin ZUMO 660. The Garmin Zumo 660 is MP3. If I down load music to the Garmin will I be able to sync it to the 20S?
If so is the a special procedure to do it?
Sena's reply
The Zumo can pair directly to the 20S. Mp4 won't be an issue, since it the Mp4 is interpreted by the Zumo and sent via A2DP on the Zumo to the Headset. So essentially, the Zumo interprets the music file and encodes it into a Bluetooth signal, which is then sent to the Headset.
You would just do a normal phone pairing on the 20S to pair the Zumo.
I hope that makes sense.
