Sena and a dongle
Sempyder
When you use the bt dongle with a Sena smh 10 or 20 s does the music still play on the speakers on rt as well as in the helmet? Or is it one or the other?
Sempert out,
Yes, the music will still play thru the speakers.
You can leave the speaker volume to its lowest level, do not mute however, because that will also mute the sound to the dongle.
You also have the option of turning off the external speakers in the Preference panel.
There is a slight delay on the signal through the dongle so you get a kind of reverb effect that is different.
