Sena 20s
I'm not sure why you would want to do that. With the Sena 20S you can listen to radio directly from the 20S. If you want to listen to music from an Ipod, Pandora or Amazon music you would pair the Sena to your phone and listen from there.
You need a SENA SM10
The radio on your Spyder is not Bluetooth you have to use the SM10 and
audio cable to convert it to work as Bluetooth so it will play into your helmet
head sets.. I have them in stock the SM10 & Cable is on sale until the 29th.
For $189.95
Give me a call 209-887-3283
Ride Safe
Dave
Can a Sena 20s pair to the radio/speakers on an F3T Limited so the audio plays in the helmet?
I got the 20s' when they first came out and the first set was horrible. Sena did put out several patches that improved the firmware. I had issues with the cases breaking, and Sena replaced both units for me. I have not put them in my helmet yet, as I am looking for a new helmet that fits better. Make sure you do the updates to the firmware, and install them properly in a helmet that will allow them to sit right over your ears. The volume is good, the range is good, and the battery life is good. I am hoping they develop a patch that will allow the 20s to "search" for units it has been synced (sp?) with if they temporarily get out of range, thereby eliminating the need to manually re-sync.
Just sayin'............
I actually decided to go with the Smh-10-11(?). Once I read BikerDoc's review of the F3Ltd's sound system quality there should be no need for in helmet, Bluetooth music. So, I went cheaper just to have an intercom with my bros and something for phone calls. Thanks for all the advice and inputs!
