Seat Removal
coronaman
Just bought a set of arm rest from ISCI for my 2012 RSS and you need to remove seat to install. Has anyone removed their seat and if so what is the best and easiest way to do this?
Not sure on the RS but on the RT there is two holes under the seat on the spyder body/plastic, that should be plugged with foam or something before you start, as if you drop a bolt down there it may never be seen again!:yikes: Also good idea to stick some gum or putty to hold the nut in place before removing the seat bolts and spacers. Besides that on the RT, remove the seat arm, unplug the cable and take out the back bolts/spacers. Not sure if it is the same on the RS, but would think so. Maybe post how you like the armrest when your done. I have Diamond R and my wife really likes them.:yes::yes:
