Seat release problem
punji
Hey all --
Pulled up to a fuel pump a few days ago and the ignition key would NOT release the season my 2012 RT Limited. Generally, when the key is pushed down and turned to the right there is some spring resistance. Now there is none. An extra long screwdriver worked the seat latch so I was able to refuel. I have removed the stainless plunger from the bottom of the seat that is grabbed by the latch so that I don't do permanent damage with the screwdriver. Anybody know how these things work and what's involved in correcting it?
Thanks in advance. Have a happy and safe Independence Day weekend!
punji
I believe that the seat release is cable-operated... Can you follow that cable back from the latch, and see if it has just come loose? :dontknow:
THE CURE
I had some real concerns about breaking the KEY in the ignition ( this is about $300 ).because of the amount of pressure needed release the seat with the KEY. So I wired the latch partially open. I just pull up on the seat and it comes up..........Please don't tell me about people stealing my or your GAS.....Not going to happen.................Mike :thumbup:
why lock the seat?
Why bother puttting the plunger back? I took mine out long ago so I would never have a problem with the seat getting stuck down and locked. I don't keep any valuables under the seat, so whats the point of having it lock down?
seat latch
Remove the latch, do not let bad people make your life miserable. The chances of some stealing anything are almost zero. Not worth the aggravation thief's have no use for your tool kit or backrest.
Tell that to the Spyder Owner that had his backrest stolen at the Owners Event in Maggie Valley, probably by another Spyder owner/Rider (Spyder Owners/Riders were the only ones allowed on the field).
Cruzr Joe
Cruzr Joe
I don't know how it is on other spyders, but, it takes all of 2 seconds to get the backrest off of my GS.
I keep my seat locked, prevent the theft of my BRP backrest.
Cruzr Joe
Good thinkin Abe Lincoln. At $449.99 or just round it out to $450 is a very expensive replacement.
I must admit once I thought my seat was stuck and was beginning to pull on it hard and still would not open and then I remembered to push the key down and TURN IT "RIGHT" who would have guest, it opened just fine. Glad I did not break something trying to get it open. It is called operator error.
:opps:
Jack
They might steal that high quality OEM tool kit :roflblack:
if there is one thing that bothers me the most, it has to be stealing. i never locked my helmet up or i would always leave the key in the bike, till one day i had a pair of gloves stolen from me on a cold day. since that day and now with this bike i carry extra gloves and a extra helmet. i also got into the habit of locking my helmet in the front frunk, and took the IPS cover off the key so i can put the key in my pocket.
In the UK that is considered to be normal behaviour!
If it isn't locked/secured/nailed to the floor it will walk!
Had the same problem on my 2012 RTL. So for peace of mind I put a long tie wrap on the release & ran it out at the front of the seat put a little electrical tape on the end so it wouldn't scratch the paint. Always opened mine like a charm. If you decide to do this test it a couple of times before you put the seat down. Also look how you run it out checking so it won't hang up. Got this idea from another SL.
Lube it
After reading the first couple of posts in this thread I knew what to do. Got the trusty teflon lube and put a few drops on all the latches and into the cable ends. It now works much, much easier ( even though my :spyder2: is fairly new).
Kaos
Thanks, all for the responses
Think I'll just leave the latch post off and use the seat unlocked. Like many have pointed out, there's nothing worth stealing anyway. At CanAm labor rates through the dealers (after a 2-hour drive) it could end up being extremely pricey.
