ARtraveler
No longer with us - R.I.P. Dwayne
I purchased the new metal shims from Seal Floorboards that go under the brake pedal. They raise the brake pedal by double the space the nut & screw set up did.
These are a great addition if you do not have them yet. I also have the extra wide brake pedals from tricled. The new shim raises the pedal height much better so that you do not have to worry about the brake pedal bottoming out on the floorboard in a panic stop situation.
I highly recommend the new shim if you do not have it.
