Saddlebag locks and latches
challman
I am owner of a brand new used Spyder..
This came to me with the r-35 Can-Am hard saddlebags on it..
I am amazed by how easily the brackets go on and off... I love it... Though I am not really taking the bags off much I can certainly imagine wanting t street machine type look to go cruizing....
Anyway I have a couple of questions to pose
1st and foremost ..... Does anyone else have troubles getting the bags to come off the rack? I push down on the button and wiggle and tug and then all of a sudden for some inexplicable reason they pop off. I just don't understand what I am doing wrong...
Any advice?
Also Keys..... Is there anyway to modify these things so you can leave them unlocked. I live in an area where theft is very unlikely I only want to have them locked when I want them locked. Now having to always have a key to get in them..
Is this possible?
The problem with the bags sticking is typical. Pushing inward, toward the Spyder, can help. Lubricating the mechanism helps, too. As to the key, I know no cure. You get used to it.
Pick up some garage door lube that is safe for plastics... seems to help.
The longer you have them, the easier they are to pop off.
They are designed to always be locked... They would potentially pop open when traveling - You wouldn't want that.
Also, the locks tend to get road grime and grit in them if you do a lot of riding in the rain... And you will occasionally need to flush them out with a decent lube... Not WD-40 (though that will work for the short term), but something that actually is a longer term, but not too sticky of a lube. I flush them before each trip and have no issues. I wish Givi had incorporated a cap for the lock cylinders.
Any advice?
Is this possible?
You want them to lock...safer for many reasons...if you're in such a safe neighborhood, just leave the key in them unless you're riding around...
I actually hadn't thought of that Probably cause I only have 1 key... But my understanding is that the hardware stores will have blanks so I can have more made.....OK then
Does anyone want to recommend a good lubricant for the latches?
Wait a second...one key? The sidebags come with 4...where are the other keys?
I bought it used and only got the one
The person you bought it from has the other three...you really think he lost all of them? That would really stink! I guess you could have more made at any hardware store, but losing 3/4 of the keys is kinda bad...
