Ryker Plastic Panels - Not Gas Friendly
EDFRyker900
So this is just an FYI for everyone.
I was filling up my tank this weekend and the gas leaked on to the plastic panels. It got on the standard black panels and faded them almost instantly to a light, milky finish. Even though I wiped them down instantly with a rag I keep in the storage compartment. So far I've not been able to fix them. I emailed Can-Am and they basically told me to go to the dealer. I let them know that even though it was my issue that the gas leaked on them, the design of plastic around a gas tank should be gas proof. Just common sense. So for now I bought new panels for myself. I'll post any responses I get from the company. The dealer said I'd probably get a gift card or something, but I'm not holding my breath.
Not happy about the situation, but for now I have a set of panels I will customize on my own since they already look ****ty. lol
That is just plain poor design. If you are going to put plastic around the filler cap then it should be gas proof. What a joke. the engineers must have had their heads up their butts that day.
I wonder if the gas tanks are made of the same stuff? Hopefully, they are steel like the Spyders. If not, they will probably crack and leak gas after a few years.
A " gift card " ……… total BS , something is wrong with that Paint..... I have a 14 RT and have spilled gas on it a few times ….heck I use gas to get bugs and Tar off my Paint with no ill effects ….. Gasoline should NOT be able to effect your Paint that quickly …… good luck …. Mike :ohyea:
The Damaged panels could be Wrapped, and I'd ask Pete at wrapmyspyder.com about whether his wraps are fuel proof, I bet they are.
Makes you wonder what all the panels are going to look like in a few years time with the effects of sun etc on them.May be a good idea to slosh a bit of stuff like this on them taking the usual precautions in case it melts them.:banghead:
I threw fuel all over mt Rally first time I filled it up - panels went white but a quick wipe with a damp cloth restored them to new condition.
How hard is it to remove the classic black panels, are there just the two push pin on either side of the front storage area?
I've filled up the Ryker 3 times. The first time, I didn't get the nozzle in far enough and a bunch of fuel shot out the cap and overflow tube (up front). The second time, I tried using the plastic funnel, but the pump didn't shut off, so the entire bike got soaked. The last time, I successfully filled it up without getting fuel everywhere. I wiped everything off with a damp towel; all of the panels look fine otherwise.
Painted metal fuel tanks are not really gas friendly either. Eventually they will begin to peel around the fill necks. Gas will mess up most material if it gets on it enough.
Been there. My first fill up at pump, more gas went down overflow tube into the ground than into the tank. I almost never ride more than 90 minutes so ofter top off the Ryker from a can before I leave.
