Last Thursday my wife [pillion] & myself were cruising along at the posted 100 kph speed limit. Always looking some distance up the road, I noticed a couple of staggered step ups in the bitumen. I could not slow down much as there were cars up my backside & I couldn't go around the stepups as there was on coming traffic. Hit these stepups at about 90kph. Jolted the bars a little, & at the same time, the left hand mirror decided to detach itself from it's mounting.:yikes: Luckily the blinker plug held & the cable acted as a tether. I reached down & grabbed the mirror as it was dancing all over the body panel below & at the same time looking up the road for some where to pull over. A few hundred meters up the road i see a slight widening of our lane & started to slow down. The RT is a manual which made it a bit of a juggling act trying to change down without using the clutch. Finally came to a stop, unplugged the mirror gave it to my wife & quickly merged into the traffic as i could not stay where i had stopped. Bugger me, i had only just got up to the speed limit, hit a repaired patch of bitumen & you guessed it. The bloody right hand mirror detaches itself & disappears from view:yikes::yikes:. I take a quick look around & see the mirror now in three pieces bouncing down the on coming lane [ luckily no cars ] & into the bush. I take a mental note of where it left the road & where i can park on my return. With a little searching i found the 3 pieces. The flasher unit itself not a mark on it. The black plastic surrounding the mirror only slightly scuffed, but amazingly the actual mirror like new. The bottom black plastic shell 1 small scuff. The top painted shell only 4 small scratches.:shocked: Really tough plastic & easily repaired.
Yesterday i received the magic mirror mounts. What a great product & a piece of cake to install. No more runaway mirrors.
So if you haven't tethered your standard crappy mounts do so. IMHO purchase the magic mirror mounts & you'll never be on edge having to thump the mirrors [WTF] again to remove them.
