The BEST thing about running Kendas up front is that they are a crap tire & they probably won't last as long as just about anything else will, which basically means 'anything better' is likely to last longer & work better while doing it? :shocked:
Yeah, I know that because the front end of our Spyders is so light that even if you do run crap tires like the Kendas & you pay reasonable attention to getting their pressures & the wheel alignment right, they'll give you a reasonable life & possibly even reasonable performance :dontknow: but that's only
IF you were lucky enough to get a pair of Kendas that weren't so crap in the first place that they could never be balanced or they vibrated all the time cos they were out of round &/or delaminating from the start... but that doesn't really mean a heap except that you were lucky in that one, they still are CRAP tires!! :lecturef_smilie:
Apologies for the excessive use of the word 'better', but when something is crap,
everything is 'better'! Just about ANY car tire in a similar size with the same or higher load & speed ratings
will perform better, last better, grip better, ride better, sound better, & even feel better; & that 'better' only gets '
even better' if you pay attention to running the right pressures & getting the wheel alignment right!! (Pretty much every other car tire out there is constructed better/stronger & capable of carrying/withstanding greater loads & stresses, so they don't need as much air in them to carry the light loads imposed by our Spyders - in fact, they usually need somewhat
less pressure in them in order to let the stronger/heavier constructed tire reach sufficient operating temp to let the tread grip better & also flex enough to provide optimal wet & dry road grip!) So why would you keep on accepting the most mediocre tire you could possibly find to fit just because it
might manage to give you a 'sorta orright' life, ride, & handling?? Especially since it's so bloody easy to get something (anything!) that will do all that a lot better, if not a HELLUVA lot better, is more readily available, does EVERYTHING a tire needs to do better, lasts longer, & is often cheaper into the bargain?!? :gaah:
Soo, you can choose just about
any car tire that takes your fancy & has at least the same load & speed ratings (probably be hard to get anything with lower ratings!!
) and you can even go a little bigger in width or profile, but probably not more than a single step up in
both width & profile at the same time. If you want to remove any doubts you might have, just check around & see what others are running successfully & take your pick; Mike's option is probably one of the better options - at least that way, if someone is already running them in a given size (width & profile for the make & tread pattern) then you'll know they fit!! But it really won't matter much, if they go on & they aren't Kendas, the odds are massively in your favour that they'll do everything better than the Kendas - and if they don't do that at your first try, then check the pressures you are running for the load they are carrying, chances are that you got that wrong & getting it right will mean they
WILL out perform the Kendas in all respects except mediocrity... still, that isn't really gonna be too hard!
