RT622, Turn Signal bulb LED replacements?
Ok, I've found that the bulb in question is a BAU15 based bulb P21W style with 30 deg off set pins on the PA6 base. Not a standard North America based bulb or base as it is made in Italy for the Canadian market. The standard 1156 base bulb is not for this socket as the holding pins are 30 deg offset. However, I've found you can push one of the pins past into a lower groove to get the bulb to fit. I've also found that you can get a BA15 1156 socket replacement base for $10.00 for a set of 4 on Az.. The LED I used is from auxbeam xd000177 Amber 1156 base.
