wanderingman
As I have read old posts I have read many posts regarding engine heating problems on the V twin RT Spyders. Was this a problem on all V twin Rt's or only certain years?
The fuel mileage with my 2013 RTL improved 4-5 mpg after the return fuel system was eliminated as a result of the recall. That was a 20-25% improvement, in my case! That seems counter-intuitive, but I'm certainly happy it happened. :thumbup:. There Is no doubt that the 2013 RT is now the best pre-1330 model. It is really "disappointing" however, that they only offered the scoops, and not the entire recall, on the other models. :sour:We have a 2013 Rt. When I bought it I did not know about heat issues. Probably would have got a different one but am glad I did not. Here in Maine the heat issue was not a big deal. I did none of the aftermarket stuff. Waited for fix from BRP. It was great. Mine was the first one done at dealer so they were careful. No more heat/fumes etc. I like the scoops and all is good. If the "fix" is in, it is good to ride. Noise levels so on are ok too. I don't see any increase in noise. Fuel mileage is about the same, maybe better(?). I don't ride for economy anyway.
Here are pics of the scoops / vents installed on Louise 2015.I also have a 2012 RT. Anybody have a picture of these replacement grill / air vents mentioned.
Sent from my SCH-I605 using Tapatalk
I want to buy a Spyder although I am unsure regarding model and am trying to get as much info as possible before purchasing. Thanks for your input.
Thanks, JC. I didn't realize that about the older fuel systems. I've often wondered, however, why the NHTSA didn't force BRP to do a campaign on the older RT's as well - especially since there were reported fires with some of them. Your post sheds some light on that also.
Can you tell me this... Why did fuel economy on the 2013 RT's significantly improve after going to a non-return system? Intuitively one might think it would have the opposite effect of lessening the mpg. The only reason for improvement I can think of is the combination of the other mods, as well as the ECM tweaks. That seems a stretch, however, considering the amount of improvement I experienced.
Also, do you know if the 1330 engines have a return or a non-return fuel feed system? This is unrelated to the discussion at hand, but I am curious about it.
The returnless fuel system gets better mpg simply because the fuel is not being heated and returned to the tank to boil off.
Not really...a non-return fuel setup is more prone to running lean and suffering from low fuel pressure when running hard. However, richen up quite a bit at idle.
Return systems are MUCH more consistent with fuel pressure. Easier to tune. Return systems are far more desirable.
i see your point, Doug, but I'm not sure how much I agree with that last statement. While it does cause the engine to run richer (thus cooler) at idle, they likely could have obtained that result with ECM programming alone. In fact, they DID do that with a service bulletin about six months or so before the actual recall. And it actually did help some, but only when you were idling or running in first gear - like stop & go traffic. However given the results I have personally experienced with my 2013 RT, the recall changes to the fuel system are indeed more than just a band-aid. They resulted in both a cooler running engine AND significantly more economy (about 25% more, in my case), with seemingly no real down-sides. To me, you definitely have to call that an "upgrade". :thumbup:IMHO the recall changes to the 13' is a complete bandaid and not an upgrade. All its doing is allowing the motor to run rich at idle. Rich fueling cools.
Easy bandaid to cool an idling motor without having to mess with EPA approved tuning and emissions.
