RT Seat unstable
agedbikeman
The front left side of my seat moves up and down as I corner as though there is nothing supporting it. I moved the seat back as far as it goes on the rear mounting slotsand adjusted the latch accordingly, if I raise the latch to lower the front of the seat it jams, in it's correct position the left cheek of the seat is in mid air, only the rear two of the four rubber cusions touch the frame. I made an adjustable rubber cussion from a car exhaust mount, drilled and tapped it into the bottom of the seat cheekas my picture shows, now the seat is perfectly stable
attachment.php
attachment.php
I also added 2 adhesive felt discs to the front rubber cusions, now they touch the frame aswell, the whole seat is now stable, has anyone else had this issue, it seems like the middle of the seat is stabalised on the frame and the front corners are left to fend for themselves:opps:
