RT Quirk??????
Bozzzz
I was was facing downhill on a very steep driveway and the RT would not move in reverse gear. It would try to move backwards and the at about 2500 rpm's it would cut out.
Is this a way of the RT to protect itself on steep grades or a problem?
Try it. Steep grade and see if you can reverse.
dumb question but was your park brake on???
RT Quirk
I really don't believe I have had the opportunity to reverse up a steep grade but the RT does have a rev limiter in reverse for safety reasons,
But should reverse at rpm you stated unless some other prob. exist...
Freebob...:doorag:
I backed mine up a pretty steep incline the other day. It did take some finesse on the throttle, but it did go.
:dontknow:
My driveway is fairly steep, and i backed up quite a few times with no problems [Sm trans] How steep was that driveway??
Mine did that the other day on a steep incline on a road. if I start on a flat surface I can back it up a steep incline but if you are actually on the incline and hit the reverse and try to drop the clutch it seems to complain and get that RPM cut out. I ended up just going forward and turning around when that happened.
Reverse
I back mine up my driveway every time. I think it's only about a 3% grade. I have backed up some significant grades in the mountains with no problems noted. In fact, I take it real slow around my GoldWing friends so I don't make them feel bad.
Patrick
Patrick
This was very steep, guessing about a 20% grade.
I've had that happen to me before. Most of the time it backs up with no problem but every once in a awhile it messes up. No explanation.:dontknow:
No problems here. I have a fairly steep driveway and back out with a passenger with no difficulty.
If it continues, and its not parking brake related, you should have it checked out.
