frank3
RT-S PE#0180
Well----think I might need some help here. Purchased a battery tender for the RT and it came with a set of pigtails for quick hook up and disconnect. Raised seat and "attempted" to loosen the bolt on the neg. terminal and found the bolt would not loosed. Turned bolt head several turns and believe there is a lock nut under the frame member that the terminal is bolted to. Can't see an easy way to access the nut and am at a loss. Looked at the pos. terminal and think it may be the same arrangement. Am I out of luck and will just have to use the clamps each time I want to use the battery tender. I would bet Lamont or some one has already attempted this and may have an answer.:gaah:
